mikefitz
Solar Wizard
- May 28, 2020
- 2,979
Not a practical or well thought out procedure. If you examine the roof in question , or most van roofs, you will notice they aren't flat, and have a curve form transverse.would lay metal frame PV panel on van roof flat and StiXall it in place over the entire frame
A further point , assuming that this method was implemented, ( requiring lots of PU sealent) is that the back of the panel now has no cooling air flow, will overheat and suffer failure.
You identified delamination as a possible issue, you can also have paint layer detachment. No matter how effective the PU adhesive is, there can be issues bonding to contaminated vehicle surface.
Correctly engineered through bolting in conjunction with a suitable sealent is 100 % effective.
