Goal Zero yeti 1250
Noel J
Needing assistance…
I’ve taken my GZ yeti 1250 apart swapped out the box replaced all fuses inside and out but…
I’m still having a problem with the DC input, I plug the 8mm blue charging cable that I have plugged into the wall and I get a display of LO battery - then flashing of green charging light. It momentarily goes off and then comes back. Battery is new and charged
I didn’t see any scoring or burnt circuits
Everything is green when the battery is in- all things work except the charging of the battery through the blue 8mm inputs- lo battery symbol and the flashing of the green light over the DC imput/solar imput
Is it as simple as a reset or do I have a very large brick I just bought a new battery for
