ravindasenarath
- Aug 27, 2022
- 5
Hi everyone,
My off grid solar system uses a Grawatt SPF 5000ES with 1800W panels and a Grawatt 4.8 kWh battery. I have set Setting No 1 to SBU, No 12 to 50% and No 13 to 95% ( default). Expectation was to use battery till 50% when there is no solar and keep rest of the battery in case of a power cut( No power in grid ). System seems to be working as expected till mid night but when I check in the morning it seems like battery has reached 50% SOC in the early morning and used utility to charge the battery.
Then in the morning when there is sun light all solar get used to charge the battery and house was running from utility. What I want is for inverter to use solar as the first priority for the load and use the excess to charge the battery.
I found a post with a similar scenario there the OP use Setting 49 to prevent battery getting charged by utility during night. Then someone suggest to set Setting 13 ( AC2b ) to minimum that inverter allows. I'm wondering how does this fix the issue. Setting 12,13 is SOC point back to utility and battery respectively. What does that exactly mean and how does that fix the load not prioritizing in SBU mode.
Thanks
Thanks
