the_uglydog
Lately we have been having issues with the grid frequency going out of the tolerated limits of our Growatt grid tie inverter. Here in this part of The Philippines we use the US type split phase system of two 110v lines to make the 220v with 60hz the frequency. Here it's not like in the US where complaints about high/low voltages or slightly off frequency will be serviced. If the power is between 170v and 270v and the frequency is between 55hz and 65hz, it's considered OK, Ours usual operates at 220-240v and from 58hz to 61.5hz. Does anyone know of a product that can be put in the utility line to stabilize the frequency to within .5hz? The inverter can be set to operate between 270v and 100v so that isn't an issue, but the frequency tolerance is only 1hz and can't be reset. Any suggestions? Thanks thedog
