OK there's a danger here that you're skirting with.
It is possible to AC-couple some solar systems, where everything inside the house connects to one AC bus. The main inverter supplies the AC power and the smaller microinverters (on the panels themselves) connect to that AC power and dump their power into it. The inverter must be designed for this, and the design/microinverters must be chosen so that they play well together. An example is frequency power control, where the inverter increases the frequency if the batteries are almost fully charged, so the microinverters know to back off.
The danger is that someone can hear that and think "great idea! I can get a small/cheap inverter and 'fool' my microinverters into turning on! I'll get free power during the day with almost no $$$." This does not work, since small/cheap inverters cannot handle the output of all those microinverters.
Another danger is that you try this with a generator, which cannot handle such inputs. Several people have destroyed their generators this way,
