DutchCookieMonster
I have:
1x fronius Symo 6.0-3-M Total PV 6090Wp 3-Phase (14x275Wp at an angle of 25 degrees and 8x280Wp at an angle of 0 degrees) (on AC-output)
1x Power One Aurora 4.2 Total PV 5165Wp 1-Phase (8x280Wp on the north, and 15x195Wp on the south (at an angle of 70 degrees) (on AC-output)
1x SmartSolar MPPT 250/70 Total PV 4000Wp (on the south at an angle of 30 degrees)
The fronius and the SmartSolar are visible as devices in the Cerbo GX.
ESS and DVCC are enabled.
Feed-in limitng active: No
The problem is:
When the batteries are full, and there is no or low consumption in the house, and the sun is shining brightly, I can theoretically return about 15255Wp. (This is a lot lower due to the location of the panels.)
The 3x Multiplus-II 48/8000 should be able to handle this.
However, when 6000Watt is fed back into the grid, the fronius is limited.
I see a settng at the fronius: Zero feed-in power limit. 6000W. Where does this number come from, and where can it be adjusted?
The problem is:
