Hi all,
Recently my NET METERING system went online. It comprises of the following equipment:
1. Fronius 5KW GEN24Plus
2. Fronius Meter
3. 12 Sharp 410w giving a total 4920kwp
4. BYD HVM 11.04kwh
Currently there is no back up mode which means that is the grid goes down the only power available will be through the PV Point (max 16amp) which is not connected. I Intent to introduce the back up switch board provided by Fronius at a later stage.
During winter (I live in Athens, Greece) I see daily productions ranging from 15kwh on a cloudy day to 23.7 kwh on a sunny day.
Instead of either buying more battery or/and the Fronius back up functionality I was think to introduce a Victron inverter with a set of 15kwh of 48v batteries and an additional 3000kwp of solar.
The logic is that I utilize all the power produced by the Net metering system and that in General all power to the house will come from Victron. The grid (and therefore Fronius) will be directly connected to the AC In of the Victron (and maybe the PV Point of the Fronius also which will mean that a Quattro will be needed) .
Depending on the SOC of the batteries of the Victron (and other parameters) the power demand will be shared with the Fronius.
Batteries of the Victron will be charged in combination to the SmartSolar charger and Quattro that will get power from Fronius.
As nice to haves are some automations not to charge the batteries from Fronius if e.g. there is no sunshine but this is less important. The max power coming from Fronius will be 20amps during the morning and 5amps during the night unless the SOC of the Victron batteries is at 20% then it will passthrough all demand to the Fronius.
Goes without saying that all works will be performed by a certified electrician providing all necessary certifications and paperwork.
Is the above description doable? Are there flaws that might create issues? I want to know before I start asking for quotes.
I am attaching a schema of the logic (there may be design flows)
2. Fronius Meter
4. BYD HVM 11.04kwh
