byteharmony
Sunny side up please.
I just realized my utility company, WE Energies has the following solar program:
$0.05 / kWh - Solar purchase
$0.08 / kWh - off peak cost 7 PM - 7 AM
$0.18 / kWh - on peak cost 7 AM - 7 PM
Here's the thing that shocked me. They want me to wire all my solar power to them through a separate meter before it can flow in through a usage meter when I use it.
I am getting a Sol Ark 15k, so that is not possible, I'll be requesting a bidirectional meter.
BUT if I did a sunny boy or enphase I think I would need to produce 3.6x every amp I use in order to have we energies to be gird tied.
Think about it.
I make 3.6 Amps = $0.18 worth of power based on solar rates
I use 3.6 Amps during the day, they charge me: $0.648
Just putting all that power on the grid tie generator input of the sol ark 15k and making your utility switch you to a bi-directional meter would improve your finances 3.6x when you are drawing your own power. Add a battery and you can bank that power for when you need it and only draw at night.
Think about it.
