Hi,
I'm pretty new at this and have read a lot of discussions on this forum but still couldn't figure out what I need for my particular setup. So allow me to explain. I already have a solar system installed since 2014 (SolarEdge) in San Diego CA and grandfathered into NEM2.0, but system is not big enough to cover my peak usage during the day. I have multiple EV and PHEVs. For the PHEV I'm constantly charging during the day because it doesn't have enough EV range. I have EV-TOU rate that I pay $0.15 from 12-6AM but more than $0.8 from 4-9PM. My idea is to get a battery bank to charge from 12-6AM and pump the power back to the grid during 4-9PM so I can use it normally without having to disconnect from the grid and/or worry about battery capacity. I read the threads about AC coupling (battery backup) and off-grid system, but none of them solves my problem. So in summary, the system should:
1. Connect the charger to the battery bank from 12-6AM, charge to 90% then disconnect.
2. Connect the inverter to battery bank from 4-9PM, invert the power back to the grid, until the battery reaches 10% or 5%, then disconnect.
Is there an all-in-one hybrid inverter/charger with TOU setting that gives me what I want? If not, what are my choices? Is this even possible?
Thanks in advance!
Thanks in advance!
