Hi All
I'm preparing to install my first ground mount array and had a question about distance between arrays to avoid shadowing . I put the numbers in a ground mount calculator but the results are that the panels need to be 18' apart from the top of the front array to the bottom of the back one...that's 30' apart at the bases. Does that seem right? The panels are about 6.25' long. Should I trust my math?
Thanks!
Thanks!
