Thank you, good to know, I can see how the ridges would complete the bond. Would one be sufficient on the frame of each panel, or would you need to add them on both the top and bottom of the panel?![]()
IronRidge XR-LUG-03-A1 Grounding Lugs, Low Profile
Shop now for IronRidge XR-LUG-03-A1 Grounding Lugs Low Profile.www.stellavolta.com
The ridges on the lug surface cut into the anodized aluminum panel frame to complete the bond.
Here is another one:
Aluminum Lay-In Grounding Lug – Solacity
Aluminum lay-in lug, tin-plated, 14 - 4 AWG, stainless set-screw & mounting hardware, cUL listed #aluminumlug #groundlug #layinlugwww.solacity.com
