I just purchased the 12000t and I am confused about the AC input and output. It seems to me if I connect them both to the same panel I would just have an inefficient loop.
My setup so far is 26 REC 360 watt panels connected to Enphase lq7+ micro inverters on a grid tied system. That system feeds into my main panel on the outside of my house, which is 200 amps. Inside that 200 amp panel are (2) 100 amp breakers that feed 2 panels down in the basement. I will be making 1 of the 100 amp panels my critical needs panel. I have mounted the 12000t next to the critical needs 100 amp panel in the basement. I have ordered from Michael here on this forum, 32 cells to make 2 sets of 16s batteries (48volts).
My thinking is when the grid is down, manually kick the 200 amp breaker from the grid to the off position(Yes I know I need to get some kind of interlock setup so no one can turn the grid switch back on with out first turning off the 12000T), then turn on the 12000t which would power the 100 amp critical needs panel, and power would go back up to the 200 amp panel. The Enphase setup would see power (thinking the grid is back up) and turn on the solar panels. The solar setup would then be providing power to the 200 amp panel then would then come back down to both 100 amp panels. (I could could kick off the non critical needs panel circuit breaker in the 200 amp panel to conserve power when needed)
So far I am thinking I can only use either the AC input or the AC output at any one time but not both. The AC input of the 12000t would be connected to an 80amp breaker in the 100 amp critical needs panel to keep the batteries topped off while the grid is up and solar power is being received from the solar panels.
When grid power is down, I would kick off the main grid 200 amp breaker, then walk downstairs and switch the wires from the AC input on the 12000t to the AC output on the 12000t then turn the inverter on.
Is my thinking correct? If I have both the AC Input and the AC output connected to the same 100 amp critical needs panel when the grid is up, I would have an AC loop right?
Please help!
Please help!
