Growatt 3000 LVM 24v x 2.
It looks like it is setup correctly for split phase and I am getting 120v from each except when I check between the two hot sides i get 0v not 240v.
I did connect the 2 communication cables (left the power sharing ones off) and set one Growatt to 2P0 and the other to 2P2, they'll correctly display HS and 2P respectively but the output is 0 volts on my double pull breaker when I would have expected 240v.
- Currently only connected to the batteries (PV and Grid are not yet setup)
- No faults or warning codes.
- LifePO4 300Ah 24v, fully charged.
Is this expected or am I correct in thinking I have done something incorrect in the settings?
New to this but couldn't find a post on this one so figured it was worth asking.
