SPF 3000TL LVM-ES split phase diff information on Inverters
prince_a
new england us
Hello All.
I have 2 questions
1. I manage to setup split phase on 2 SPF 3000-ES inverters, one is HST one is 2p2, no error between them, but if im scrolling along the inverter configure on 2p2 im seeing that the config isn't the same and on top of that it shows as 50hz and not 60 HZ, checking the 2p0 HST shows the information correct .
should I reset both inverters and reprogram or there is an issue ?
2. both inverter voltage screen dont match 100%, there is a 2V diff . the main server with the NIC connection is correct and show the data from the battery, the 2p2 shows less voltage. weird ?
thank you
