JohnGalt1717
- Dec 22, 2021
- 107
I apologize if this has been answered somewhere else. I did a search and couldn't find anything.
I have JK BMSes that apparently don't talk to the Growatts, otherwise I'd just RS485 them and be done but... since they don't...
In the Growatt it has options 12 and 13 which are obvious enough for the battery (after you set US2 in option 5) But then options 19 and 20 are where it gets confusing for me:
19: This says that it's constant voltage. In a normal world I would expect that this is the voltage at the knee where the charger should switch from CC to CV for the remaining portion (like from 90% to 100%) and that there would be a cutoff voltage that would be higher than that. But there doesn't seem to be a higher level. I'm targeting 3.5V for my batteries so should 19 just be 56V and call it a day or am I missing something? I would have expected 2 options, one at about 3.4 (the knee) and another at 3.5 for cut off.
20: This is float charging voltage. Is this really a think with LiFePO4? Or should this just be at an arbitrarily low point? I've seen varying different answers to this. Andy at off grid garage says that this should be 3.4 * 16 = 54.4 but I'm not sure.
43: Equalization. This doesn't apply to LiFePO4 correct?
Thanks!
Thanks!
