Has anybody gotten the Growatt to communicate with these Hitachi batteries? What's the correct protocol? What could I have done wrong here?
I'm having problems getting the communication working between my Growatt 6000T and my Hitachi ESM-48100B1 Lithium Battery bank.
I have three of these batteries connected with RJ-45 cable and a terminator in the end. I'm quite sure the connections themselves are fine. The batteries balance themselves, and the Growatt unit is charging and working pretty much fine. But the Growatt don't read the battery percentage properly ++ without the communication.
The Growatt unit has a configuration option for Litium batteries. As the manual says "In order to communicate with battery BMS, you should set the battery type to “LI” in Program 5." But it don't work. With any of the four BMS communications protocol options I just get battery errors.
The cable between the inverter and the Hitachi BMS is a standard RJ45 cable, the manual says: "Make sure the lithium battery BMS port connects to the inverter is Pin to Pin. The BMS port supports communication with BMS by RS485 protocol or CAN protocol."
This is the battery:
Lithium Battery ESM-48100B1 - iSitePower Integrated Smart Site V100R001C00 User Manual (ICC1000-A1-E1) - Huawei
Version:V100R001.C:01075363,01075363-001,01075363-002
support.huawei.com
