I’ve seen a couple threads on this but haven’t found a definitive solution, and before I went ahead and did all the research I figured I’d see if anyone came up with this already.
I have a Growatt 12k SPF inverter with a custom battery bank (Tesla modules with the EVTV BMS).
I’m looking to take advantage of the percentage options on the Growatt when it can receive values from a Lithium BMS.
Thus far I’ve found:
Growatt and Lithium batteries use RS485 to communicate.
I found a document from Growatt on their rs485 communication.
I wanted to see if anyone had come up with some code (don’t really care about the language) to talk to one of these inverters over the BMS/RS485 port to send battery metrics to it.
I already have code that pulls the cell/battery voltages from the EVTV BMS so I need to be able to transform that and send it to the Growatt. I can do this myself but haven’t run anything over RS485 before so I figured I’d see if anyone here had something they had used/written that I could build off of.
Thanks!
Thanks!
