JonV
I have a Growatt MIN5000TL-XH inverter and am trying to collect data for Solar Assistant (which seems to be working fine). I have configured the USB to RS485 as per the instructions but I am not getting any TX/RX lights on the RS485 Converter and therefore no data to Solar Assistant. Is there anything I need to do on the inverter to get it to transmit data? I am using two internal wires from a CAT5 cable and have tested continuity, but nothing is coming out of the RS485 port
Converter info
https://www.waveshare.com/usb-to-rs485.htm
Growatt configuration
https://solar-assistant.io/help/growatt/tl-range
Any ideas?
Thanks
Converter info
Any ideas?
Thanks
