B bioshock New Member Joined Sep 1, 2022 Messages 1 Mar 13, 2023 #1 can someone please help with battery that can be used with Growatt SPF 5000 Es ? want to buy from alibaba thanks
T timselectric If I can do it, you can do it. Joined Feb 5, 2022 Messages 18,605 Mar 13, 2023 #2 Any battery for a 48v (51.2 nominal) system will work. If you want to use BMS communications. You'll have to find one that is compatible for that. Which makes it a little harder.
