hello all,
New to solar so be gentle. I have recently installed a Growatt SPF5000es powered by the Hope Growatt 4.8kw lithium battery connected via BMS and 3000 watts of solar. It ran fine for a couple of weeks but now will randomly shut off completely and restarts around 2 minutes later with no fault codes present. Im finding it does it during daylight hours but doesn't seem to matter if its sunny or overcast. a few times it has failed to restart and i have to switch it off and restart the battery then the unit. Im well inside the charging parameters producing around 200 volts at 6 to 10 amps. Ive reached out to Growatt here in Australia a few time and dont get a responce. Any help would be greatly appreciated as ive been looking everywhere but not found anyone with a similar issue
