I'm in the process of adding solar to charge the 48v electric motor battery bank in my boat.
The Growatt I ordered arrived today and was just reading through the Manual. One issue I've found with it is that the preset "Lithium" option appears to ONLY WORK WITH Growatt lithium batteries. There is an option for a user-defined profile, and I think that would allow me to input suitable parameters for Lithium. The manual posted on line (version 1.0 - 40 pages) doesn't make this clear, but the one that came with the unit (version 2.0 - 45 pages) is more detailed about Lithium battery connection and communication.
However, I just went to check the MPP unit's manual and it doesn't have a Lithium preset at all. It has only the "AGM" and "Flooded" presets and the custom mode. So either unit, you will have to appropriately program to use your own Lithium batteries.
While the units are very similar, The Growatt does appear to have some extra features, and some of the specs appear to be marginally better. The main reason I got the Growatt was that the US importer had the Growatt available sooner.
