carniola
Hello,
I plan to install an 11.9kw solar power plant with a 20.45kwh battery soon. Inverter will be Deye Hybrid inverter, 12kw.
I have a question about the connection of a heat pump to an inverter. I use a 15kw heat pump for heating my house, which I intend to connect to the GEN port (as smart load port, always on grid, battery off at 50%).
I wonder if a 12kw inverter is powerful enough for a 15kw heat pump.
Thank you
Thank you
