BilTheGalacticHero
I'm setting up a heater for the LiFePO4 battery system I've built for my Jeep. The battery will be located inside the Jeep and surrounded by foam but we're often out in below freezing conditions and I need a heater so I can charge. This is the battery...
It has a thin ABS case. I got a four pack of 25W silicone sleeved heating pads of Amazon, the same as others have used...
I've been experimenting with two in series and they get to something like 130-140F just sitting on their own. If you put anything on them to absorb the heat (like even your hand) the surface temperature drops to around 100F. I was planning on using just the two pads. I've seen advice to stick them to the side of the battery or under the battery, either with or without an aluminum heat spreader. It appears some people are running four in a series-parallel configuration but that seems like a lot of heat. I'd really like to hear where people are placing these and how (and how many).
In another post I got advice just to tape the temperature sensor to the top of the battery case but I've been reading more threads here and see other people say to attach it to a battery terminal. I still can't decide what to do. The battery case is such thin plastic it really makes me wonder.
Looking forward to hearing (more) advice.
Thanks in advance!
Thanks in advance!
