packrat1969
- Nov 30, 2021
- 18
Today I finally received the (4) cells I ordered from Shenzhen Basen Technology back in November. Some 97 days ago. They all appear to be in great shape physically. No dents, scratches, or bloating, but I have some doubts to the actual manufacturer and the capacity. I was promised Grade A CATL 302Ah cells, but other than the sticker the vendor applied to each unit, I can find nothing confirming either. The QR code area on each cell isn't much more helpful, but it is broken down into 4 different elements:
1) The QR code itself. So far, I am unable to get my phone to recognize it as a QR code. It is tiny. Probably less than 1cm square. I will keep trying.
2) A unique 14 digit number that is possibly a serial number, but may have a built-in date code. All 4 numbers start with "21", probably meaning 2021, though I do not know how they incorporate month and day. Example: 21051085000108
3) The number: 1921816. The same on all 4 units
4) The number: UPTA-191. Also the same on all 4 units. This seems like it might be a model number. So far, no luck searching for it here or elsewhere. I am not going to be happy if these turn out to be 191Ah cells.
The QR code is offset from the centerline and is closer to the cell's positive terminal.
Has anyone else run across these cells and been able to verify their capacity? I have yet to pick up the rest of the tools and materials I need for assembling these into a working battery, but eventually I attempt to load test the lot.
