Help configuring solar trickle charge for Golf Cart
ryanohall
Atlanta, GA
Hi, I am looking to build a system to trickle charge/maintain six 8-volt deep cycle golf cart batteries while in storage for a couple months. The batteries are wired together as a bank. I plan to fully charge them prior to hooking up the solar system. From researching, I think I need a solar panel(s), a solar charge controller and the wiring to tie everything together. I would really appreciate any advice on the products to buy so I can install it soon. Thanks!
Any controller compatible with 48 volts is fine. Probably need a couple solar panels in series to produce close to 60 volts.
Don't exceed the controller ratings and it is pretty much plug and play.
