I have got 10 x 55ah batteries I have posted a few times about them, they are all second hand so no idea of age or remaining capacity and I originally had a few problems with them going out of balance so I bought an active balancer and it has worked pretty well but spotted one in particular was getting more current then the others. There is a LED on the balancers to show which way the flow is going.
So I decided to pull it apart and bought a capacity tester so I could get the best 8 of the 10 back in 4s2p for 48v.
Tested B1 10amp draw to 12v and got 23.38ah
Tested B2 10amp draw to 12v and got 9.39ah
Tested B3 10amp draw to 12v and got 9.03ah
Tested B4 10amp draw to 12v and got 10.65ah
Ran a battery repair on B1 and B2 and got
B1 23.33ah
B2 6.01ah
So declared B2 dead, B3 and B4 probably as bad
So I took B3 and tested C20 discharge rate 2.75amp to 10.5v to get total wh which was 411wh out of potentially 660wh battery so roughly worked that out to be 36ah capacity out of a 55ah battery so not dead but not great but also obviously not less than half of the good B1 battery.
Decided quickest way to weed out the bad was a new test C10 5.5amp down to 12.4v
B1 10.27ah (known good from previous test)
B10 9.99ah (marking as good)
B2 6.56ah (known bad)
B3 1ah (know bad but was similar to B2 in other tests)
So comparing B1 to B2 over the different tests;
Test 1 B1 is 149% better then B2
Test 2 B1 is 288% better then B2
Test 3 B1 is 57% better then B2
During the test;
B10 (good) started 13.6v ish dropped to 12.8v ish once loaded then worked down slowly to 12.4v
B1 (good) started 13.6v ish dropped to 12.42v once loaded then recovered to 12.62v after a few mins then slowly down to 12.4v
B2 (bad) started 13.6v ish dropped to only 13.2v once loaded and slowly dropped to 12.4v
B3 (bad) started 13.2v ish dropped to 12.45v once loaded and dropped to 12.4v
Nothing seems to be consistent.
I feel like if I charge again redo the tests especially anything but B1 the results will be different.
Batteries are Lucas LSLC55-12 says on the front VRLA, doesn't mention AGM but most websites do so is it potentially charging with a standard lead acid charger I think it goes to 14.6v 5.9amp constant current then constant voltage down to .1a
It is not as inconsistent as this when it is on my SCC's but I am not obviously watching it for hours on end.
B1 23.33ah
B2 6.01ah
During the test;
