shihan
so currently my power comes from the street....l have setup 2 x mpp 11kw max inverters with 36kw panels and 2x10kw batteries. l would like to disconnect the street power however connect it as backup power to the inverters.....(Temp), So where l need help is with the neutral wire from the street. The active from the street will be disconnected from the power board and connected to the inverter backup connection but what about the neutral, does it get disconnected as well.....because you have the active coming from the inverter and the neutral from the inverter....hope this makes sense.
