Hello! With a decent amount of time on my hands I decided to build a small 10x10 aquaponics greenhouse. Since I don't have access to electricity in that area of the yard I decided to go solar. I am trying to power roughly 750 watts of equipment (3 water pumps, air pump, 2 fans, and a shop light that is rarely used) for 24 hours a day. At night, the power consumption should drop by a little less than half. I completed the build and everything works great but I can't get through a 24hr period without my batteries draining. I'm in San Diego so I believe I should be getting adequate sunlight. I'm not sure if my configuration is wrong or if I'm just not setting the charge controller correctly. This is my first build so I'm sure I did almost everything wrong so please don't be to brutal. Any suggestions, corrections or recommendation would be greatly appreciated!
- 1 Longi 310w 24v solar panel (LR56-60HPB-310M)
- 1 800w pure sine inverter (I would eventually like to go to a higher watt inverter if possible)
- 1 Epever - tracer 30 amp charge controller
- 2 Alphacell 150 XTV batteries - 12v 80Ah (wired in parallel)
*charger controller shows full charge by the end of the day but drops from 3/4 to 1/2 charge quickly once I have the system running.
I know I should have done more research before I started but I got eager to get my first build started....
