Hi all and apologies if this is not the best place for this question... here goes.. I have a PowerJack 6000w 24v inverter. I purchased it some time ago and would like to use it as a "off-grid" backup. I have a small 24v LofePo4 battery charged from solar panels. Normal stuff. The inverter has a hardwire connection and I was going to hook it up to a small panel with a four (4) 15 amp breakers for critical plugs, these will NOT be part of the normal power but in case of emergency stuff. The issue I have, the inverter is marked with a L1, N, and P. Im assuming the P is ground, however when I check the voltage between N and P I get 120v, so L1 and N is 120 and P and N is 120. This seems odd to me but I am not an expert per se..
Looking for some assistance on wiring this to the panel based on the 120v from N to P. Also the voltage from L1 to P is 240... Thank in advance...
