So I have a victron 100/50 wired to 4x200w panels on the roof of a trailer, and also a 100/20 controller installed to use for a separate ground panel or two. These are both connected to a cerbo s gx/starlink for remote control and monitoring.
I have roof mounted floodlights that I would like to control in what victron refers to as "Streetlight function", lights come on after dark utilizing PV voltage as the clock. Total lighting circuit power consumption will be a little less than 10 amps @ 12v.
The 100/20 has a physical load output connection, whereas the 100/50 load output is via the Tx port I think (part of the VE direct port?). My roof panels are wired 2s2p and come through the roof into one double pole breaker, then onto the 100/50. Currently, the lighting circuit is wired to the 100/20 load output connection and working well, but in order to sense night time (pv voltage from roof panels), I have to tap into the output of my roof panel breaker and wire into the 100/20 PV input terminals. This obviously negates the intended use of the 100/20, and currently the charging function of the controller is disabled, so I need a non 100/20 load output solution for powering my lighting circuit.
I have searched this forum as well as victron community with no luck, which is very surprising to me honestly. Also have combed through the cerbo gx s manual and 100/50 manual.
Is there a way to have my 100/50 load output control my lighting circuit via the same streetlight function via a cerbo relay?
If not, what physical hardware am I looking for for a non-smart solution? Some type of relay + contactor that will sense voltage from my roof panel breaker and then send power to the lighting circuit? I know this can be done, but I don't know what specifically I need.
Any help would be appreciated, thanks.
