OleMan2765
- Oct 10, 2021
- 62
Will has a video on YouTube that is 17 minutes, 27 seconds.
Will shows using a power resistor crossing the 150a switchable fuse as to prevent the arc of the connection.
Reviewing his video, he changed to a 300a fuse, which will have an arc when connecting it.
My system came with 2) 200a inline fuses where he shows the switchable inline fuse.
I have three 48v 5.3 KWh LiFeP04 batteries to connect.
I will have a big arc when connecting for the first time.
Any ideas how to get around that?
My inline fuses have a warning as to not replace with power on. so I could not use the resistor, then connect the fuse.
Can I use the resistor to charge the capicators, then turn off the batteries to make the connection?
Just don't want to burn anything up.
Thanks..
DIY 13kW 48V Offgrid Solar System: How to build it from scratch!
The exact system I just bought.Will shows using a power resistor crossing the 150a switchable fuse as to prevent the arc of the connection.
Thanks..
