I am installing a 512V high voltage battery system. However, when I connected the 50KW Deye inverter, the battery did not charge normally. The battery supplier asked me to turn on the monitoring system and found three protection messages, all from leakage protection. Check out the images below:
We are measuring the voltage of the positive and negative terminals of each battery and the ground wire to check whether each battery has leakage. But the result is no voltage.
The supplier asked me to disconnect all the ground wires, but it seem to not work . The battery monitoring system shows that the battery is still protected, and neither the charge/discharge relay and the pre-charge Relay is turn on.
Professionals, do you have any suggestions, Thanks in advance for your help.
