ChrisM78
Evaluating options for adding battery backup to an existing system…. Including a ton of background info in case it affects answers or gives anyone an idea I have not thought of yet….
I have an existing grid-tied system with 2 x Fronius Inverters (one 10K and one 15K). Each inverter is fed 2 strings from a large 78 panel array. House has 400A service which is split into 2 x 200A panels. One inverter is on each panel. This system was professionally installed and works great as it sits. However…if grid power is down the inverters obviously shut down and I am without power. I have manual transfer switches in place for each panel and have a couple large portable generators I can fire up if needed. I would like to add battery backup but the inverters are not hybrid inverters and I cannot replace the inverters or modify the system due to the tax credits etc. Because of this I cannot really automate failover without going with something similar to an AC Coupled PowerWall ( which all seem to be way more $ than a DIY option). Building a 48V battery bank and inverter to power each panel in the event of a power failure would be fairly easy and would give me a manual failover to battery power instead of to the gas generators. I would like the ability to charge those batteries off the existing solar in the event of an extended outage (which is the issue I am trying to figure out). I know I can wire up switches or quick connects to rereoute the strings from the grid tied inverter to the off grid system….The problem I am running into is that these Fronius inverters support a very high input voltage for the strings (up to 1000V). 3 of my strings are in the 600V to 650V range when operating in colder weather with the exception of one that can sometimes peak around 710V with the right conditions, I cannot find any MPPT charge controllers or Hybrid Inverter units that can handle that kind of voltage. Does anyone know of a model that can handle that or a way to reduce the voltage without rewiring the existing strings (remember I cannot mess with them due to the tax credits)? If not then I think I am going to be forced into an AC Coupled battery backup system that can utilize and cycle the existing inverters….
Thanks in advance for taking the time to read this and for any ideas.
Chris
Chris
