You can power loads from the EV battery, only if the specific vehicle has a charger that is bidirectional.
dcbel claims to have DC charge and discharge capability to the EV. I’m not aware of any EVs supporting DC fast-charging that also support DC discharge, but that is the capability to keep an eye on.
Discharging a battery in DC is a far, far easier proposition than discharging in AC. The EV essentially becomes a high-voltage battery that offers it’s stored DC energy to the hybrid charger/inverter like any other battery. The hybrid does all the heavy lifting of deciding how much power is needed and inverting it to offset loads.
So far I do not know any EVs that have an onboard charger that can do that. the Ford F150 has announced 240V output but the price tag is expensive and I do not know when they will be available. My definition of Vaporware is announcements without installed product. Pardon my scepticism but the F150 and dcbel fit that definition..
You are right to be skeptical -we’ll believe it when we see it.
But AC out is already a common feature in many hybrids. They integrate inverters running off if the 12V battery (so very limited power and energy levels),
Changing that to an inverter running directly off of the EV battery for higher efficiency and greater output levels is a straightforward upgrade and that is all the Ioniq 5 and F-150 Lightening have claimed.
So simple V2L capability running off an islanded AC out port that has nothing to do with grid sync is easy-peazy, only costs a modest amount more than what the average hybrid already offers today, and I’ll be very surprised if we don’t see both vehicles launch with that capability when the hit the market later this year.
I’m assuming your skepticism is focused on the ‘V2G’ and home-backup capability meaning EV’s directly powering a critical loads panel.
You should certainly be able to peer a fridge through an extension chord. Powering a full backup loads panel means bushwhacking some wiring or getting an electrician involved who will insist on a transfer switch at a minimum and possibly additional safety features (so that’s a very different proposition than the ‘using an EV-like-a-generator’ approach that I’m discussing.
The dcbel hybrid inverter/EV charger may prove to be vaporware but the architecture is a natural and extension of the high-voltage hybrid inverters already in use and I believe the arrival of something like this is inevitable.
If the EV standard for DC charging does not also allow for DC discharge, then the problem is with the standard, not the concept.
Inverting power from DC to AC can be dangerous, principally because the AC power needs somewhere to go and so proper throttling must be performed by the inverter (which gets more complicated if that inverter is in the EV).
For an EV to throttle DC power costs nothing - just allow the EV charger access to the EV battery terminals the way it already has access for DC charging.
If DC charging requires a bunch of electronics within the EV between the charging port and the battery, the whole thing is more complicated than it had to be and it will take much more time for DC discharging capability to materialize than it could have.
I was all set to buy an Ioniq 5 and still may but I’m now going to hold off to understand more about the show DC charging and DC discharging landscape…
