offgriddle
"FOREVER BEGINNING"
I have an Epever tracer 4215BN 40 amp SCC with 150 VDC max solar input.
I have two, 100 watt, 12 volt solar panels hooked up in series and they are rated for 21 volts each open circuit and
I was reading about 41 volts with no load at the SCC array input terminals, no problem there.
ACCORDING to the specs which I have right here in front of me in the users manual:
The Rated charge power for the SCC is 540 watts at 12 volts or 1040 watts at 24 volts
The Maximum PV Array power is 1560 watts at 12 volts and 3120 watts at 24 volts.
Do the above specs mean that at 24 volts, I can have a 3,120 watt array?
