SteveDeFacto
- May 16, 2022
- 45
Trying to add additional charging current to my Quattro-II. Decided a IP22 BSC 24-Volt 16amp should be sufficient. I purchased it and wired it into my system but realized the charging voltage was way too high as my batteries are only supposed to be charged to a max of 24.4v.
However, unlike my Quattro-II which can be set as low as 19v, the BSC can't output a charging voltage below 25.6v. There doesn't appear to be anyway to set it to a lower voltage.
I am considering purchasing a Victron Phoenix instead since it appears to support VE.Bus, I'm thinking it will let me configure it using VE.Config which let me set a lower voltage on my Quattro-II. However, this is just speculation and I need confirmation from someone who has used a Phoenix.
Anyway, how can I charge my batteries at a lower voltage using a BSC and if not possible, will a Phoenix charger work instead?
