ShelbyWatson
- Oct 24, 2019
- 45
So, I've hooked my 6 solar panels in series, which will make the volts add up. Volts times 6. If I change this to having 2 sets of 3 panels in series, the calculation would be 3 times volts with the amps times 2. Connecting the two sets of three together in parallel. The two sets (series) will be connected by positive to positive and negative to negative. (Or parallel)
If I am understanding correctly, this will allow me to hook them up with a lower voltage than if they were all hooked up in series.
The panels are rated at 100 watts each. I know that watts are a calculation on volts times amps. So, I'm assuming in connecting in series I am modifying total watts? Or am i still dealing with 600 total watts?
