wpns
Solar Joules are catch and release
Designing an add-on to my existing solar system so there are a lot of moving parts and options, but I'm having a lot of confusion over some of the available 'kit' systems I'm seeing online. [I'd like to get a complete kit of parts, so there's one supplier, but of course I can roll my own, plus or minus supply chain issues and even more moving parts.]
My strong preference is a string inverter, so as to avoid RFI issues with cheap, poorly engineered inverter-per-panel systems. I'm not sure how SolarEdge Power Optimizers work, so I don't know if they are going to have the same RFI issues, but that's a question for another post.
I'm seeing systems advertised which produce "watts per hour" and "KW per day", and my person favorite, systems rated in "WK", so those are easy to weed out. However, a few systems look OK until I add up the OCV on the strings and compare to the maximum input voltage ratings of the inverter, and discover they are 35% over the limit! Are they cheating and using the MPP of the panels? Are they just not engineering it right?
My understanding is that OCV of the panels times the number of panels in a string at the lowest operating temperature should be less than the maximum DC input of the inverter, no?
Thanks!
Thanks!
