Ok so the 20a charger has input v of,120. 120 x 20 = I need a 2400 watt generator? Seems highAll you need to know for gen sizing is the input wattage. The manufacturer will tell you what that is.
20A charger: 20A is the battery DC charging current, not AC input current.Ok so the 20a charger has input v of,120. 120 x 20 = I need a 2400 watt generator? Seems high
Current stays the same because current is controlled by the charger.I d-nt think anything. In fact I know nothing about lifepo4.
I thought the,current,stayed the same up until they are fully charged. Voltage is also,high all the,way to the top and then drops to,float.
current only,drops down for la battery?? Or am I wrong?
But they do list the ac I nput??? Input voltage: 1 Phase 120VAC 50HZ/60HZ ± 2HZDo you have a link to the charger you're considering?
Edit:
Oh look. They don't tell you the a/c input for that charger. Must not UL listed.
Thanks for the link. I’ll do some reading. I’m new to lifepo4 batteries.Current stays the same because current is controlled by the charger.
Once the voltage reaches the set charging voltage, the current starts to fall.
The higher the initial full charging current, the longer the ramping down takes.
Its certainly not fully charged once it reaches the set charging voltage.
There are several different lithium iron chemistries, they differ but the general characteristics are quite similar.
The curve below shows what happens if you charge at 1C.
That is charging at 100 amps for a 100 amp hour battery.
Once it reaches full charging voltage, it has only reached 60% charge state.
It takes several times as long to reach full amp hour capacity.
Suggest you visit "battery university" its an excellent resource, the best on the internet for battery facts and figures.
https://batteryuniversity.com/article/bu-216-summary-table-of-lithium-based-batteries
Yes, I know the 20a is charging current. I multiplied current by voltage (120) to get wattage as I thought dc and ac was all the same and only power factor and efficiency mattered Ac input current should be 2400 watts?/ no?20A charger: 20A is the battery DC charging current, not AC input current.
So the charger is junk? Stay away?They don't list input wattage or amps which is what you need to figure out exactly how much power it will draw.
Otherwise, use your estimate based on output plus like 20%.
The 20A is the DC charging current to the battery, you cannot mutiply AC input Voltage to the DC charging current to get the AC power input.Yes, I know the 20a is charging current. I multiplied current by voltage (120) to get wattage as I thought dc and ac was all the same and only power factor and efficiency mattered Ac input current should be 2400 watts?/ no?
For example (assume 100% effi. to simplify the calculation)
Charger is rated at 12VDC 20A so the power is 12V x 20A = 240W
So the AC current will be 240W/120Vac = 2A of Ac current, so 120Vacx 2A = 240W.
If effi. is 90% then it will be 240W/0.9 = 267W pulling from the AC outlet.
Yes, based on 48V nominal, as the the battery Voltage goes up toward the set point the Wattage will go up with it, also the Power factor comes in as explained.so my linked charger requires 1066 watts from genny?
(48 x 20 = 960 watts. 960/120 = 8 a. 8 x 120 = 960 watts /.9 = 1066 watts?
this is the math needed for dc chargers?
who makes a decent 48 v charger? Do I look for up listed? Something that lists ac input current?
I can always put the charger on my killa watt (meter) and charge it “on grid”. Then I’ll know the true power it needs, and buy my genny accordingly.Not junk. It's just lame of them not to have a rating tag for how much juice the thing will draw.
I don’t have the charger.Well why didn't you say that in the first place?
just learning and wanted to know the math.
I don’t just want to know what to do, I like to know why I’m doing it.
I figured it was ribbin, lol. Glad we both understand that.I know. I was just giving you a rib'n. If you're committed to the battery and voltage, yes of course buy the charger and batteries and just plug it in and see what it draws, then buy generator.
This is the smartest way.
