glock35ipsc
I'm sure this is a simple answer, but I've probably overthought it to the point that I'm now confusing myself.
I have a SunGoldPower 3kW/24V inverter charger. I operate it as a battery backup, so the inverter only comes on when the mains go down. I also have 2500 watts of solar connected.
My question is...... when charging the battery from the on-board AC charger, either from the mains or a gas generator, how much power is required to operate the charger itself? It is using 120VAC to power the charger, but output is 24VDC (25.6V nominal, or up to 28.8V I suppose). So, is it using 120VAC * 40A = 4800 watts? Or would it be 25.6VDC * 40A = 1024 watts (+/ for exact voltage)?
I don't know if it's a simple as that, or if there is some conversion I need to take into account considering its AC in and DC out. I would like to know this to be sure my generator will handle it and that it's not being overloaded.
