Dadoftheturkeykids
I know this has been discussed many times here, and reading into it I think the general conclusion is;
Overpanel as much as you want, just don't go above the voltage limits of your charge controller.
Is this true? What if I doubled the input but stayed under voltage?
I want to know if I can put two 545w panels in series on my 40amp solar charge controller charging a 12v battery bank.
(I am aware of the losses, and aware that if I were to have a 24v bank, it would fit the
CC parameters perfectly)
This would be temporary until I can afford to buy 4 more controllers (i have 4 currently)
or a suitable 24v inverter. As of right now I only have a 12v inverter, but have 8 of these panels I want to utilize/mount now.
SCC- RichSolar 40a mppt (100v max)
Panels- Trina 545w (37.9 VOC)
If I series 2 panels together that would give me 75.8voc @ 17.24a, which is way more than my controller can feed to my battery bank, but will it have any negative impact on my controller?
