Tenukitime
Hi all, I'm building some solar powered remote surveillance systems. This is my first time messing with off-grid solar, and I've learned a lot from these forums.
One thing I can't quite figure out: can I oversize my solar panel to the charge controller?
I'm using a Linovision POE-SW805G5U-Solar switch as the basis for my build. It is a 5-port network switch with a built-in solar charge controller. It has PoE out ports that will power the cellular router and the camera equipment. Seems pretty great as everything will be 24v, no need for an inverter, very few wires. I've got it running on shore power at my house now to get a baseline for power consumption, but I think I'm going to want as much as I can get. If I need to run a separate charge controller, I will do that, but if I can maximize the power output from this one, that might simplify things even more.
The charge controller states that it has a Max of 300W. So my question is, can I do a solar panel greater than 300W, and it will only provide 300W of power through the charge controller? Or if I hook it up to a 380W panel, will it blow the charge controller?
Thanks for any input!
