I am new to solar energy solutions, but since power outages have become frequent in my area I have purchase a solar generator. Need some guidance determining the panels arrangement. Per my research I know I need to consider the solar input limits of my generator, in my case a Delta 2 with input limits 11-60V, 15A, 500W max. I know that for panels in series should consider voltage and in parallel current. My confusion is that some say to consider panel’s Vmp and others Voc for voltage, and for current some say consider panel’s Isc and others Imp. Also, other say consider voltage and wattage only, current is normally regulated my the charge controller. Can someone please clarify which specific parameters I should consider for series connection, parallel or series/parallel? If is true that the input current is not that important as voltage in this application? I will appreciate all the detail information that can be provided, since I am a beginner. Thanks in advance.
