The trace suggests the battery voltage is reaching absorbtion voltx, 28.4 for 'smart lithium setting', then dropping to float at 27 volts.
Over the period of the trace the battery has been reaching a higher and higher SOC after each day. June 12 was the first day the battery reached absorbtion volts.
Since absorbtion volts also equals protection volts, its possible the BMS is entering protection. Suggest increasing protection volts to 3.65 or lowering absorbtion volts using expert mode to 28.20 or 28.00.
Mike
