Falling
Hello,
I recently upgraded to a Chins 400 AH Smart Lithium from a Renogy 200 AH AGM. Now I am having trouble with temporary battery disconnects due to high voltage spikes.
Setup:
Battery- Chins Smart Lithium 400 AH.
Solar Charger- Smart Solar MPPT 100/50.
Solar Charger Settings- Default Lithium settings in the Victron Smart Solar
Monitoring- BMV 712 Smart
Monitoring- Chins App
Problem as I see- When a load comes on or drops off while getting full sun, I get a momentary spike in voltage. Typically the spike is around 15.1. The time length of the spike is hard to tell but I can tell it is long enough to trip the BMS. From Chin's app I can see that it disconnects the charge and discharge. The app shows them getting disconnected. Chins app will not allow me to adjust any of the BMS settings. After a few seconds the voltage drops back to normal and the battery restarts charging and discharging as normal.
I'm at a loss for what to do. Has anyone seen this problem. I can't imagine it's good for my electronics.
Thanks for any help.
Setup:
