So I will be using these Power Queen MPPT/DC to DC Chargers to Charge my Lead acid starter battery. One will take Power from a 35W solar panel and put it into the battery during the day, And the other will take 12V From a LFP battery (charged by a 200W Solar panel During the Day) And put it into the Lead Acid Starter battery at night. My problem is how can I stop the one hooked up to the LFP From charging during the day and wasting Power? And Will both of these be able to handle when the Battery jumps to 14V From the alternator, And then stop charging since it will think that the Lead acid is full?
Another Alternative to this would be to just have one Charger, But then I would need to Connect the two solar panels That I will have. One is a Lensun 35W And one is an Ecoflow at 100W. The Lensun is 17V, I'm having a hard time finding the Voltage for the Ecoflow (haven't bought it yet). It says 17.1V 5.9A which is 100W, But then the description says 12V 45A which is obviously wrong, so I have to assume that its 17V, and id be able to check once I get it. But I'm not sure whats the best way to connect them? I'm reading that parallel would work but means if one has shade then they both barely work, or something about the 100W one being limited because the 35W is so much less?
