i am experimenting with setting up a simple solar system to replace electric meter at entrance sign to home development.
Been successfully with an older pair of 40 watt panels that I got free plus a 10 watt LED flood that is adequate for sign. I added good charge controller from Renogy and am using a 12v 54AH AGM battery that I acquired for nothing. Actually have two of these batteries that were removed from service after 5+ years of use as battery backups or something. I have tried individual batteries and also have parallelled them to try that. Obviously I am not getting full charge on these since I run sign light each night. I also feel my 2 panels would be best replaced with an 80 to 100 watt modern panel (mine are probably 10 years old or so from a portable RV charging system).
With poor sunlight this time of year I am struggling to keep enough charge in batter(ies). I'm thinking I should get a new battery properly sized. Since I've read that an 80 watt panel under the best conditions can charge a 35AH battery in a day, is this the proper size battery I should buy? Question is... Is it better to have an oversized battery in AH or one that is correctly sized for panels and load?
