I think you guys make a general mistake when considering to cool your stationary vehicle off-grid with an AC unit.
In order to cool a car properly in the summer, under sunlight, the stock AC is often at the maximum it can pump out, and my minivan AC for instance, has a really hard time fighting the Florida heat and humidity. When the car was parked in the sun, it takes the AC about 12 minutes too cool the front row down to some mid 70s degrees and that's basically where it stops, running at full blast. Maybe a core cleaning and fresh refrigerant will improve this a little, but not by a lot.
Now, many homes in Florida the size of 2,000 sqft run on a 2.5 ton AC unit. Guess how many tons your average sedan AC puts out. Up to 3.3 tons / 40,000 BTU. All those 2,000 BTU toys won't do crap.
Don't underestimate how much energy it takes to cool down a standing vehicle in direct sunlight with basically zero insulation.
I'm converting a minivan to a camper right now. The inside of a car in 90 F summer temps and direct sunlight can reach over 140 F. Getting it down into the double digits is the primary goal.
This is what I do to archive this goal and that doesn't require me to run the engine or generators:
1.) Buy a white vehicle or one with a very bright color and metallic paint. Both helps to reduce the temperature inside by reflecting parts of the UV and visible light.
2.) Install window tint with ceramic coating, not just cheap limo tint. Install on all windows, even the windshield. They offer films with no or minimal tint. The ceramic coating reflects UV light.
3.) Install window vent shades / deflectors and keep the windows cracked by 1 inch.
4.) Run a fan inside that cools you down.
5.) Find the cabin exhaust vents, remove the flaps, do some ducting to the inside of the cabin, and install large PRESSURIZING computer cooling fans with the highest airflow rating. Good ones move 120 m³/h (that's 70 cubic feet a minute!) Most cabin exhaust vents can be found low, behind rear bumpers etc.
6.) These fans run on only a few watts. Keep them running with the windows cracked even when you are not inside the vehicle. Maintaining 85 F inside a car is much easier than having to cool it down from 120 F.
The fans pump cool air from under the (white) bumper into the vehicle and push the hot air (goes up) out of the cracked windows.
