John Frum
Tell me your problems
- Nov 30, 2019
- 15,230
Honest mistake really. I didn’t quite get the not “bumping” values.
The BMS LVD is 20 and the CC value is 22. Is that what you mean?
The charge controller should not be in the load path.
Please don't do that, even if you have fire a extinguisher under your pillow.
You should have a low voltage disconnect for your inverter to protect the bms from the brutal assault of disconnecting a load at significant amperage.
As I've said quite often, The bms is a "reserve parachute".
See my previous post where I recommended a solution.
