I have 2 SunGoldPower SP6548's to run in split phase, I have 200amp T-Class Fuses for each inverter. I have a bigbattery 48V CNDR Elite 11.8kwh. I have the power coming from the inverters 2/0 awg on positive to T-Class fuses to bus bar and the negative directly to the bus bar just like in Wills blue print. The battery cable I received from big battery i think is a 6 gauge but will said the battery should be wired to the bus bar with 4/0 guage which is twice the thickness of the 2/0 wire. I called big battery and they told me to order from a third party company in kentucky which the largest wire they have is 1/0 awg to a 175 anderson connecter which I ordered but dont want to this up.
Am I going to find a 4/0 AWG anderson connector or is this safe to hook up, because I am a stand still and I am a very very beginner. Thanks for feedback in advance.
